Not the EU, but CENELEC. Decided by sound old fashioned electrical engineers.ericmark, as suspected, the EU to make things a little more compatible, rather than a sound old fashioned electrical approach.
endecotp, I am beginning to think I do.
A 13A fuse when the appliances draws around 4A is way over rated.
I was reading that they put 13A fuses in because the same appliance will sell in Europe where they have 16A radial circuits and no fuse in the plug.
A household 100W tungsten has a cold resistance of 42 ohms. If you switch it on at the mains peak then you've got 8 amps of instantaneous inrush.
On that note, here's an OT "next in the sequence" puzzle
12
1112
3112
132112
And then it's 311311222112Is that it,
Oh that's long(ish) term.I hope you got your thingy sorted! (don't say too much here)
Sorry to hear that, however, the manufacturer of said item - you don't say what it was, should have done a better job of designing/protecting their product. Also, a fuse is not a 'catch-all' for every electrical fault that can occur.However I have also had an appliance become faulty and catch fire = house fire and the 13A fuse did not blow. Interestingly when the fire brigade dragged the unit outside the mains lead was fineI'm not saying a lower, or more closly 'matched' fuse would have prevented the fire, but it may have done.
Back to the topic, I found a 1A mains fuse in a lamp which had blown as the bulb had blown which is a nuisance failure.
So a reason to use a lower value fuse where possible may be a potential lower risk of fire, it's just a wiki, but this is corroborated here http://wiki.diyfaq.org.uk/index.php?title=Fuse "Using a lower fuse value where possible can reduce risk of fire."
I have seen a 5kW pool heater tested using a standard 13A plug and operate at over 20 amps for over 10 minutes without blowing the 13A fuse, so it is possible to heavily overload the appliance. Yes a lead in free air may be rated to take this overload, but what if it is under a pile of washing, or someone has stored some insulating materials where the cable runs?
I recall my dad telling me of a job he got called out to back when he was a jobbing lecky. This particular one was to a joinery workshop, and they couldn't make one machine work - it just wouldn't start.Not always easy to prevent single phasing when a fuse blows, ...
