I'm not the 4amp washing machine guy! Mine have 13A fuses and ~2kW heaters inside and no, I haven’t changed them from 13A to 10A even though they may still operate with a 10A fuse.
apologies for my mixup!
That's no good. What's the point of being alive if your house has burnt down?So I argued that heat detectors would be pointless as they only work on after a fire has broken out. Apart from saving your life it does not save your property.
Surely what you want in a kitchen is a rate-of-rise heat detector?A smoke detector does both, though it may become nuisance in a kitchen, better safe than sorry!
Which will happily allow >1kW of heating to take place within the load for as long as it takes to be destroyed by fire.So my choice would be to fit a 5A for a 4 amp load rather than a 13 amp from the standard stock.
THere are also many types of fuse ( fast acting, delayed action, anti surge ). How would you address the matter of fuse fatique ( tired fuses ) when the fuse is carrying current at its rated limited with the fusible link at high temperature. ( the fusible link can be much hotter than the external surface ). Five amp load, 5 amp fuse, ( standard plug fuse ), how long before the fuse reduces to a 4 amp fuse and then blows when there is no fault, just the normal five amp load.There are many ratings of fuses available, not just 3A and 13A. And that is for a reason, but many can't see it.
If an appliance draws 4A then a 13A fuses fitted in a plug is irresponsibility and raises the fire risk.
Risteard, Once again Ray Tay, you haven't the slightest clue what you are talking about.
It seems a whole raft of us do not know what we are on about to you. BTW, doesn't Ireland use the European system?
The only preferred ratings in the Standard are 3A and 13A. If using other ratings you would need to check the manufacturer's data for Zs etc.
No it isn't.They do not deal in building wiring, but they know electricity for sure. It was clear to me that electricians stop at the appliance as that to them is not their responsibility. They are only concerned with the wires and flexes to it. That to me is irresponsibility.
No it doesn't - see above.As I have stated, and a few back my view on here, the appliance current rating must be taken into account. If an appliance draws 4A then a 13A fuses fitted in a plug is irresponsibility and raises the fire risk.
...but there aren't that many cable sizes. See above.There are many ratings of fuses available, not just 3A and 13A. And that is for a reason, but many can't see it.
It's not nonsense. It is not specified in the way that 3A and 13A are because it isn't a recognised rating.Using a fuse lower that 3A/13A and having to check for Zs is nonsense.
They aren't to BS 1362 though, so you're talking about a completely different type of fuse.I often use 2A vs 3A fuses in sensitive equipment like alarm panels
So, your gripe IS with the manufacturers then.Some makers are pretty irresponsible.
Why don't they? It would take NO effort.But responsible installers should use common sense and apply fuses using a professional approach.
It's nothing to do with the rating.I am sure you agree with me that an appliance having a 13A fuse when rated at 4A increases the fire risk.
