A
AlexCarp
Few, to none, of these people who make money from fitting pipes could figure that out.Yes, that's one of the big problems with combis - you either have crap DHW or a grossly oversized boiler for CH, or both.Boiler is too big.
That doesn't actually solve the problem. The heat demand is highly variable, and so the required flow rate round the CH circuit(s) varies. So there are mutually incompatible requirements for a minimum flow rate round the boiler, and a variable flow rate round the CH circuit(s).Get a correct sized boiler and fit zone valves and pump.
Got it! Even with a thermal store with a plate heat exchanger, when the DHW pump is pumping to the plate and the boiler pump is pumping hot water into the cylinder from the boiler, the hot water from boiler get sucked into the DHW plate - some are designed to do so. One circuit takes flow from another but does not adversely affect it. The flow rate in each pumped circuit, boiler, CH and DHW is still is not affected by others.That's what the debate is about. The ideal low loss header has negligible pressure drop across it - so the different circuits don't interact. But in practical terms, it's not the end of the world if the 3 circuits interact a bit - it's still a good deal better than the normal system with the pump working hard through the ABV most of the time, with plenty of noise as a result.
