Even with the ends on, surely the lids flexible enough to tuck each end under, then clip in working along the lid, to remove pop off from the middle again
And there's me been doing it wrong all these years.
This is screwfix's error, in that they've shown the trunking upside down,
I've used these pointing in all sorts of directionsThis is screwfix's error, in that they've shown the trunking upside down, and this give the impression that you put the cover on the wall first.
No he hasn't - don't be daft.He's simply taken the picture from screwfix, and assumed that that's the way to fit it - easy mistake for a beginner.
I may be mistaken but the OP said he was taking the picture from the wall side so we could see the clips were not engaging, must admit I am baffled as to why they don't, looks like normal trunking to meI did laugh when I saw your post BAS, beautifully done if I may say so, but the OP posted a picture where he was fitting the cover to the wall, and then pushing the channel down into the corner piece, hence why it wouldn't lock in to place. He's simply taken the picture from screwfix, and assumed that that's the way to fit it - easy mistake for a beginner.
the OP posted a picture where he was fitting the cover to the wall, and then pushing the channel down into the corner piece.
Me too, if there the same make, the only time they dont go on is usually when you cut the lid too long and the tabs hit that, if anything there usually loose and fall off.I may be mistaken but the OP said he was taking the picture from the wall side so we could see the clips were not engaging, must admit I am baffled as to why they don't, looks like normal trunking to me
I think he can but with tees and angles, hes struggling as he has to push the trunking into the angles, or push the angles oto the casing, so at least 1 casing hinders pushing it onto the other casingI still don't understand - even if there are problems as stated - why the cable cannot be installed before the cover and corners are fitted.
