This whole project seems beset by a combination of insufficient knowledge, insufficient thought, insufficient research, and an apparent desire to overcomplicate and use inappropriate components. An LED driver for a fan?
A light bulb for heating?
What on earth is wrong with using a 230V 100W enclosure fan heater?
The light bulb (located at the bottom) for the box, which measures 900x500x400, is supposed to heat the internal area to roughly 60degsC. The moisture, from the drying meat, is sucked out of the top by the fan.
In that case an LED driver in the box will fail quickly. They are not designed to run in an ambient temperature of 60C.
I plan on running the electrics on the outside of the box. The fan will be mounted in the wall.
I have bought and mounted a MK Shockguard Batten Lampholder. The cable runs straight into the back of the box and is connected to the lampholder already.
My dilemma is really regarding powering the fan. However I've now bought a small junction box:
http://tinyurl.com/lguga5g
I just need the 230v to 12V converter now.
