So will it do biltong?It even says beef jerky!
First thing that you notice with Biltong is that it is cut against the grain of meat, something that differs with most Jerky products.
Then you see that Biltong is spiced and flavored somewhat differently because of the use of pungent ingredients like vinegar, which is used as a pre-marinade.
Finally you will notice that Biltong has a different cut to it, meaning that each strip is generally twice as thick as its beef jerky counter-part.
Apart from being quite a lot thicker (IME more than 2x) jerky, which must mean different drying requirements.Finally you will notice that Biltong has a different cut to it, meaning that each strip is generally twice as thick as its beef jerky counter-part.
http://www.biltongguy.com.au/beef_jerkey_vs_biltong
Not a great deal of difference.
Wiring:
https://flic.kr/p/nGHj7D
I think the feed at the bottom that heads off to the plug could be a bit more secure. Any suggestions.
