- Joined
- 27 Jan 2008
- Messages
- 25,081
- Reaction score
- 2,915
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
On the building of Heathrow Terminal 5 we found some lighting sets with 110 volt sockets were in fact from a 110 - 0 - 110 volt generator and we had to blank them off. It does happen from time to time also the other way around where a 55-0-55 transformer is used on a control circuit which only has fuses on one live wire the other live being a common return unfused which should have been neutral.
Other than shaver socket I have only ever worked on one IT supply. It was part of a Robin tunnel boring machine control and lighting were from a delta wound transformer oddly the supply (660 volt) was star wound which makes me think it was a step up transformer being used to step down.
At Sizewell 'B' we had a problem finding extension plugged into extension plugged into extension most with four sockets and as a result overloading and tripping out. The three phase transformers had two three phase sockets so we started making up three phase spiders this mean three sockets one on each phase but also a 4 pin plug so it could only be plugged direct into transformer it could not be daisy chained. As the job progressed we needed 110 volt power in areas where there was no 415 volt power so we started using 25kVA transformers and 32A three phase extension boxes each with 9 sockets three 16A three phase breakers and it worked well. It is the only site I have seen 3 phase 110 volt used like this. We also had very large vacuum cleaners with 3 x 10A motors these also used the 16A three phase sockets.
With the three phase the cores were Brown, Black, and Black with Green/Yellow earth it was before we started using grey as a phase colour.
It was working on the 63 - 0 - 63 volt supply that made me think about core colours before that I had not really thought about the fact there should not be a blue core in a 110 volt cable.
The larger site transformer 4kVA and above always have the MCB on the 110 volt side as well as 400 volt side but up to 3kVA it's common to have a little red reset button on input only. My maths is 3000/55 = 54.54 amp line to earth which is well over what a 1.5mm flex can carry.
Personally with RCD protection I don't think there is a need for 110 volt any more 230 volt is safer as RCD protected and has much less fire risk then 110 volt.
