Broadband and telephones
I was about to make that same point. When directly connected your laptop has a globally visible IP address and is open to port scans and all sorts of attacks.
I'm guessing you're just demonstrating that it can be done without a router. I'm also guessing that your usual setup is using a router (or some other box) to provide a Firewall in addition to the the one included wither your OS?
Yes, it's a quick way to prove if the router is a problem or the fibre line is a problem. I wouldn't run it without a router routinely.
