cables near gas pipes
8 Sep 2005
Cleveland
today i seen a 10mm Earth tie-wrapped to main gas pipe, is this aloud? i thought all electric cables had to be min 25mm away from gas pipes?
yeah
and it also goes into top of the outside WP box to connect to it, shouldnt it go in underneath to keep IP rating?
earth cables must be exempt from this rule as they are connected directly to the gas pipe, "ordinary" cables should be a minimum of 25mm apart to avoid arcing if the insulation is broken, an earth cable cannot arc to the gas pipe if it is connected to it.
What about earth cable and gas pipe going straight into top of outside WP enclosure, wouldnt it be better if they went into bottom keeping the top waterproof? Is there a regulation on this?
Oh right.
It doesn't really matter then.
It's not waterproof, so any water that gets in the top will just drip out the bottom.
Weather resistant maybe, but not waterproof.
It would be normal to use the bottom entry on an electric meter box.
As for the tie-wrapping, I believe that is non-compliant, but I have not yet found the reg. I'm sure there is a reg that says something like,
"cables must be supported by independent means..."
Rob?
Earth and pipe work should only enter the gas meter box from the approved bottom 'knock out'.
Earth cables should also not enter a cavity gas meter box through the back internal 'hole' that the gas pipe goes through.
