My wiring centre has the room stat terminal on its left, positioned vertically, above the "heating valve" terminal, (which in my case is not used). The cable from the room stat comprises just the three - blue, brown and earth wires. The room stat terminal in the wiring centre has four terminals. Working from top to bottom:-
Brown wire to terminal marked 1
Blue wire to terminal marked 2
Earth, or green and yellow wire to terminal marked 3
Between no.1 and no.2 terminals of the block there is another terminal marked with the "E" symbol . This is not used in my case.
On the other side of my wiring centre lies the "mid posn or HW valve" terminal block. This receives the cable from the valve itself, and the cable set up is easy to follow here because the terminal has labels for the cable feed positions. However on my system I noticed that there is no brown wire in the valve cabling, and therefore the terminal marked "brown" is not used.
In summary, cable feed from the valve to its terminal is, top to bottom:
.....grn/yellow (at the top)
.....brown (not used, no cable)
.....grey
.....blue
.....orange
.....white (at the bottom)
Please bear in mind that the wiring positions shown here reflects my set up using Honeywell equipment.
Your room stat cabling has four wires interestingly, so I'd be inclined to make the true earth wire - the green and yellow - into the terminal marked "E", and the common, green wire into terminal four.
I hope this may help.
Mike
.....grey
.....blue
.....orange
Mike
