You've changed subject.
What happened to your idea that we are at record co2 levels (for the past 50 years)?
If this slides into the ocean global warming will soon be put on back burner
https://halturnerradioshow.com/inde...visible-atop-exact-ride-of-unstable-land-mass
No tsunami warnings currently:If this slides into the ocean global warming will soon be put on back burner
Sorry, it was Monruist.Where did I say that?
Quick, shove some pipes down their and hook up the heat pumps!
Something that always puzzled me about coal, I could never imagine all those trees toppling over on top of each other & just laying there waiting for something to come along & cover them up. There's the last rotting remnants of an Oak stump in my woodland that I remember being significantly bigger from a boy.
It wasn't until quite recently that I learned all coal was laid in a period before approx 350 million years ago, before the fungi & enzymes that rot wood had evolved !
Well I thought it thought provoking . . .
Time ... the carboniferous period when most of the coal on earth was created, lasted 60 million years. If you dig down in a peat bog today, where decomposition is also almost stopped, you go back 5-10000 years in just a 5-10 metres. So, 10,000 years creates 10 metres of peat, 60 million years .... 6km of peat formation (not all at once in the same place, obviously). Then that is buried and crushed through plate tectonics and coal if formed under pressure and heat.
And, the process actually caused a massive depletion of CO2 in the atmosphere and we came close to global glaciation, which would probably have been the end of life for a very long time. We were lucky CO2 levels stayed high enough to avoid this.
60,000,000 years is a very long time. We've done a good job at burning a lot of that formation in the last 200 years.
I always thought that the decomposition rate in a peat bog is down to the Ph levels & the lack of oxygen. Cool, & thank you for setting me straight.
Are we talking about the same time period?
I concurr that lots of folk gets confused between the odd millions of years in the general timeline of history, but I think that the formation of coal is a whole eon away from the relatively modern phenomena known as "peat".
To be precise, we are of-shoring our pollution production, but our consumption/use remains.so if we achieve targets by importing goods from China we are just off shoring our carbon use.
It's an interesting diagram isn't it.As usual, the graduated in f#ckall only look at the minuscule irrelevance of a nanoparticle to feel they're right.
In this case is 50 years, basically an instant in terms of earth life.
Try this:
Don't worry, this has been thought of and it is being factored into economic plans.My concern with UK etc having targets is this:
over the last say 50 years Western economies have shrunk manufacturing sectors...because they buy from China, India etc
I really don't think you meant to post that - LOLAs usual, the graduated in f#ckall only look at the minuscule irrelevance of a nanoparticle to feel they're right.
Try this:
