Can you answer the question? (He won't)
It was volcanic activity.
Man is only a tiny speck scratching at the surface of the earth
The effect of consuming any natural resources we find will be infinitesimally small when related to the size and age of the planet
And also why was there frost at night right up until June and snow on the mournes?
And we call that 'global warming'?![]()
No climate change.
Now tell me. Are the ice caps melting? Yes or no?
Then what is it? Everything else has been ruled out except human influence.
No climate change.
Yes, your right. I forgot that 'global warming' was yesterday's term. When they found it wasn't getting as hot as they thought. they moved the goal posts and called it 'cimate change'. That's actually a good term for the scientists/politicians/green industry because it can mean anything you want it to mean.
So, if the earth hots up, its climate change. But if the earth cools down, that's also climate change. Brilliant ruse.
You seem convinced that CO2 is culprit. How do you explain the fact that whilst CO2 has risen dramatically over the last 13 years temperature rise has been flat and actually has slightly dipped? Climate scientists have been a bit panicky about it for a year or two now and were pinning their hopes on a reversal. But the May figures are in now and the dip continues, which was a bugger. Any ideas?Look - face facts. So-called man-made climate change is a myth.
It's just one of the myriad of imaginary worries that man as a species has to keep dreaming up.
So what you're saying is we can burn every last drop of oil, burn every chunk of coal, chop down every last tree and burn all the gas since the dinosaurs and it will have no effect?
Will it have an effect or not?
