That's the problem - a sustained overload simply won't do that.blow the 13 amp fuse in the plug ??
http://www.esc.org.uk/fileadmin/use...product_safety/Extension-lead-test-report.pdf
Seems a lot of work and trouble rather than just screwing on of these to the wall via the keyholes>
http://www.computerstar.co.uk/produ...-gang-mains-2-metre-power-extension-lead.html
True, 20A would be - but I'm trusting that the OP was telling the truth when he said that the total load 'wouldn't be anything like 13A'.Which is about 20A. Enough to make the fuse and plug hot enough to become destroyed.As John says when fed from a 13 amp plug the maximum load cannot exceed the current the fuse will pass.
Fair enough. As you said, we discussed that fairly recently.I'm sure he was - just cautioning re the generic risks of multiple sockets on an FCU or a plug, be they a home made assembly or a purchased multi-way strip.
I actually intended to raise that point when I wrote yesterday, but forgot to - i.e. pointing out that having a lot of sockets on a 13A fused spur (perfectly acceptable to regs) is not materially different from what we are discussing here (an FCU bearing the brunt, rather than a plug/socket). What you now say indicates that you essentially agree with that.It only needs a CH breakdown to cause someone to plug a 3kW heater into one of those sockets and all of a sudden you've got a potential problem. ... I think from now on I personally will be advising people to not install fused spurs serving more than one socket.
Sorry if we've confused you. As I think you probably suspect, the short/simple answer to your question in 'no' - i.e. there is essentially no difference. In both cases, all will be fine if the total load is well below 13A (as your will normally be), but problems could arise if people started plugging in large loads (bringing total to above 13A) - that's why some people (like BAS) are a little nervous about either!Thanks for the help, and for completely confusing me. Ok can someone answer me this:
Is there any difference in buying a switched 6 plug extention lead or wiring 3 double sockets on to a 13a plug?
