Hi All,
Here are the images I put together of the current setup:
and proposed setup:
The area of concern is the CH tank which is used as a buffer for UFH, and heated towel rads. May be used for some rads in future, but not connecting them at the moment.
The hope is that if the UFH needs heat, the boiler will heat up the buffer quickly, so it remains in condensing mode and does not cycle. This should be the most efficient way to use the boiler, even if UFH heat requirement is low.
Issues appear to be boiler cycling with current setup, and not being able to heat the tank beyond 50c.
Note: there are no NRVs in this design, as heard they should not be needed.
Hope this helps clear up matters.
Note: all this is installed as per 'current setup'. I may add a weather compensating kit, if it could be fitted to this system, but no chance (i.e. money) for buying a new system from scratch.
and proposed setup:
