CPCs will (hopefully) always "be within 50/Ia and will not require supplementary bonding". It's when something (e.g. a pipe) does require supplementary bonding that BS7671 requires connection of that bonding to the CPC (even though the CPC itself will not require bonding).No, the CPCs will be within the 50/Ia limit and will not require supplementary bonding.Yes, but you are proposing to describe as 'supplementary bonding' the connection you propose to install (just connecting two pipes) in order to allow (other) supplementary bonding to be omitted. Are you saying that there are two types of 'supplementary bonding', one which does, and the other which doesn't, require a connection to CPCs?
Fair enough. So, given that you are calling it 'supplementary bonding' even when supplementary bonding is not required, are you saying that there two variants of 'supplementary bonding' - (a) that which is 'required', and therefore which also has to have the BS7671-specified connection to CPCs and (b) that which is 'not required', and therefore does not have to have the specified connection to CPCs?But that only applies IF the item requires supplementary bonding.Fair enough - but, as I've said, if this "IS" supplementary bonding, why is it immune from the requirement that it should be connected to "the terminals of the protective conductor" of each circuit in the room?
I don't really know what one should call it but, as above, you seem to have created two variants of supplementary bonding - one of which does, and the other of which doesn't, have to be connected to CPC terminals in the room. Is that not the case?What else is there to call it? It is additional; that is all supplementary means.This whole discussion arises because you are insisting on calling your connection between two pipes (and nothing else) as 'supplementary bonding'. If you called it something else, I think we would probably be totally in agreement
Kind Regards, John
