Dangerous?
I applaud you for trying to help your colleague but there are many other considerations to take into account when deciding if this installation is safe. Since the installation cowboys have made such fundamental errors you can't have any confidence in their abilities to correct the faults.
The boiler manufacturers instructions only tell you half the story...there's a raft of other regulations to comply with.
Since Lee will not do the sensible thing and have the lot inspected I advise you to give up....he's a lost cause, otherwise it will all come back to you...end of friendship.
You learn in this game that some people are a waste of space....and no amount of persuasion will convince them...so bale out now.
I hear what your saying... I think the problem with lee is he just don't understand.
when I initially told him about the problem and the danger his reponce was the waters still hot...
I feel I cant leave it, I know these guys have actually fitted the same system next door... chances are they have done the same thing.
the building used to be a single guest house 2 into 1, its now been split up again, the the heating and electric always remained separate and never crossed.
Before the building were split the boilers were installed... one was replaced then just weeks later the boiler in the other building broke down and it was decided to just "upgrade"
without going into detail this was due to marriage breakup (splitting building back up)... so not exactly on speaking terms to warn of the possible danger just lerking next door. (she wont even answer door to us!)
Ok, so how long is the run and the number of bends, and finally what size pipe.
22mm pipe from meter... don't know how many bends, its quite a few, due to the way the pipe has been routed.
got to say its a good run of about 25meters...
Why did I just know you would say something silly like that :rolleyes:
25m plus say 10 bends = 30m
The max gross input is 5.3m³/hr
In which case the minimum pipe size should be 35mm :eek:
this is a quite bazaar setup, a few years ago this would have been considered a comercial install.
frankly most domestics no nowt about pressurisation.
i have never seen the blow off piped up hill.
yes its all wrong regard the vessell cold and prv.
as for the gas im surprised to see 22mm 55,6kw input. whats that in cubic meters.
meter should allow 6 cu M/hr U6 E6
but on a domestic u6 e6 at that rate expect 19mb before the emergency isolation expect 19mb and 14mb at the appliance bs 6400
I think Bazaar is the wrong word WDIK, the lot is dangerous and wants a proper inspection.
The max gross input is 5.3m³/hr which is why I asked if there were other appliances on the system.
Doing a quick calc on 25m run plus 10 bends the minimum pipe size needs to be 35mm, therefore it will be seriously undersized at 22mm.
