D
Deleted member 267285
Can a DIY person repair that fault ( by cleaning the ceramic ) or should the owner employ a registered person qualified to work on the ignition circuitry / components of a gas hob. ?
Yes it does seem a stupid question but it is a gas related item. Common sense is needed.
A homeowner can do this, like they can remove a cooker with a bayonet type fitting to clean behind the cooker, and this is classed as none gas work. If you read and interpret the gas installation (and use) regulations 1998, you would know this.
