I don't understand, you have a electric hob, you must have a 'cooker circuit' ?
or maybe not
. This electricity socket which looks just the same as the ones in my lounge has 2 wires hardwired into it protruding out from beneath.
Do you mean the MCB trips?whenever i switch the oven and hob on at the same time it throws the power in my lounge
32A is very standard for a cooker circuit. More is rare, and unnecessary unless you've got some monstrous hotel-sized cooker.My cooker/hob in my cu is only on a 32A mcb
They should not have put it on a socket circuit, but as I said that's unlikely to be why the breaker trips.-i have a feeling this is why its been happening-shouldnt the guys who put it in have known this
There are plenty of people trading as electricians who shouldn't be.-it is a domestic electrical fitting company
Doing what?btw-they spent time looking at the wiring too for the cu fitting
For switching 2 things.What is a 2 gang unit for. It is just that i thought a 2 gang electrical socket was for 2 plugs ,and i have seen 2 gang dp switches?
When i get an electrician to install my dbl oven and hob, is there a certificate or something that i should get or receive? I would like to safeguard against bad workmanship or at least know i am safe.
I agree with securespark, but unfortunately the world is not as simple or as perfect as you seem to imply. Any work undertaken by an electrician should come with some paperwork (at least a MWC) from that electrician, but I am afraid that does not necessarily "safeguard against bad workmanship" or guarantee that you are safe. As when employing any trades(wo)men, there is no real substitute for using an electrician who comes recommended by people you know and trust.WRT the cert, the very least you should get ought to be a Minor Works Certificate (MWC).
The supply live (red or brown) goes to supply L1 and the neutral (black or blue) to supply N1.2. Wrt 2 pole switch, if N1 & L1 supply and N2 & L2 load, does that mean the 2 appliances are both connected at the N2 & L2 connections so both N2 & L2 each have 2 wires going in as its a 2 gang DP Control switch? If thats the case, what makes it a 2 gang switch as opposed to a 1 gang switch. Sorry i know its probably a stupid question, yes i know its twice as big but with what inside over a 1 gang one.
Yes, you will need a 45A switch.4. Wrt Diversity, my cooker is rated (230-240v. 50hz 4400-4800w). My hob is rated (240v 50/60hz 7000w). These are the items i am looking to have installed. Is this the information you need to tell me if i need a bigger than 32A Mcb to go with a 45A DP Control Switch?
Saves getting up.Forums are brilliant.
