No, it would be two completely separate switches so four supplies (L&N twice) and four loads (L&N twice).
Goodness - I'm very surprised that Mr MK, or all people, introduced that confusion. It's a bit like the recent discussion about 2-'way' lighting, and the way in which the word 'way' was being used with different meaning there as when it is applied to a switch. Here, Mr MK seems to be using '2-gang' to refer to the size of the plate, which is the context of a switch is, as you say, more than confusing - I would call it plain naughty!What that means is it takes up the space of two single switches. Confusing to say the least. As I did not realise it was 50A I never thought of that. Not exactly the correct term. It is definitely not a two-gang switch.Mr MK said:2-gang
One does, indeed - and I'm still surprised that MK are the culprit. It gets almost laughable when you look at their grid stuff - they sell a '2-gang' (i.e.double-socket size) surface back box and 3-gang and 4-gang grids and plates to fix to it - and, of course, they also sell 2-gang and 3-gang plate switches which fit onto a '1-gang' box!Yes. I was going to say that I can understand a two-gang back box being so called, but, thinking about it, it does not even accommodate two accessories - that's a dual - merely a two-gang socket which we call a double, but to call this a two-gang switch is definitely misleading. It just goes to show - you have to know what you are talking about to know what you are talking about.
All very true, but they are all usually bits of paper issued by the person who undertook the work- so, in terms of what we were asked, I'm not sure they can really be regarded as much of a guarantee about the quality of workmanship or, necessarily, the safety of the installation (or even the safety of the work that was done).There is an Electrical Installation Certificate which is required for new circuits and new consumer units.
This will also include a schedule of inspections and a schedule of test results. If an EIC is not required an Electrical Installation Minor Work Certificate should (I maintain) be issued. All circuits should be tested when work is carried out (except very,very minor work). Presumably the test results will be recorded somewhere so may as well give the customer a copy.
Well, that's all that was asked, but the following sentence indicated what he hoped the answers would achieve, when he wrote:True but I thought the OP was just asking which certificates there were.
When i get an electrician to install my dbl oven and hob, is there a certificate or something that i should get or receive? I would like to safeguard against bad workmanship or at least know i am safe.
where does it say that? I just looked at the picture you posted and I can't see it.The side of the box says its a 2g
As regards ,the dbl oven and hob operated together throwing the sockets in my lounge and dining room, here is a photo of my cu. hope it can help.
