That's all true. I suppose you have to balance that risk against the risk that things at least as bad might happen if a disaster were to ensue and you were taken to task for having done nothing to prevent it other than 'advising'.Quite possibly, but the second you start costing someone more money and causing them to be held to ransom your name will be dragged through the dirt, it may not be your fault but it won't stop them badmouthing you to others ultimately even costing you other jobs.Indeed so. I suppose that (even if they chose to ignore you), if you could demonstrate that you had also contacted the DNO, that might protect your backside even more?
Kind Regards, John
