Really the onus is on you to prove a requirement within the Wiring Regulations for certification to be issued for the replacement of an accessory which is not being relocated (and quite clearly was not a distribution board).
Does that mean that, if you were providing (on request, for a price) a minor works cert, you would leave the other bits (earth continuity, IR, polarity, RCD tests) blank?
That depends what is agreed in advance obviously. It's all academic as I wouldn't be claiming responsibility for existing wiring - merely for the replacement of an accessory, so the certificate would be of little real value.
"For an addition or alteration which does not extend to the introduction of new circuits, a MEIWC may be used."
I read that 'may' as 'may be used instead of EIC'; not 'may or may not bother with any certificate'.
It's not really about 'claiming responsibility' for anything - it's to do with documenting the results (and providing the customer with a copy of that documentation) of whatever tests you feel are appropriate as part of the work you have been contracted to undertake.
I would not want to fit a replacement shower without testing the circuit - polarity, RCD working, EFLI at least.
So you should (may as well) give the customer a copy to show you care, if nothing else.
I must be missing something, here. I would not want to fit a replacement shower without testing the circuit - polarity, RCD working, EFLI at least. So you should (may as well) give the customer a copy to show you care, if nothing else.
If I were having work of any sort done which required testing of one sort or another, I would expect to receive a copy of the test results as part of that job - not 'for additional charge' as Risteard suggested.
