Used to make me laugh buying e.g. a £14.99 kettle in Argos and the screen giving you the option to buy an extended warranty for £2.99 or whatever it was![]()
Then when you try to make a claim, they say it's normal wear and tear.
When you're a sparkie, you don't care about warranties.
I never knew fridges depreciate too.I wonder how much energy I would save with a new fridge over 6 years. New fridge £180 - minus the £26 I would of spent on a new stat = £154 so would i save £154 over 6 years ? is that the correct math ?
If its a normal fridge then not a lot. If its an inverter one then yes, you might save a couple of pounds.I wonder how much energy I would save with a new fridge over 6 years.
This is partly my thinking that if I buy a new stat at £26 then as its 28 years old there must be something else that is about to fail - like a leak or something not fixable by me.Just fit a new thermostat and take it from there. Small repairs should be allowable but something like a fluid leak or a compressor failure then ditch it away and buy a new one.
The seals could do with replacing I suppose, there is lots of scratching on the inside base from 28 years of sliding the salad crisper (what ever f-ing use that is ) in and out which is difficult to clean stained from mouldy cucumber and the like in the past so its probably not the most hygienic of places to store food.Plus the cost of energy saving, over the years..
