Yes, ok.If you could run 6mm² or 10mm² cable all the way from house CU to a garage CU, things would be different, because you could then have a higher-rated MCB in house.
And ofcause that would require re-running a cable through the house, and spending twice as much on the swa running down the garden. Circuit lenght is around 12m inside and 8-10 outside.
Daniel
