You think this law is silly, so advise that it's one to ignore.
Firstly, I did not 'advise' - I merely stated what I personally would be comfortable to do - because I feel that I could put up a strong defence in terms of the 'spirit' (and hence my view of the intent) of Schedule 4 of the Building Regs.
However, BAS, for one, is totally convinced that 'the law' does
not require notification of work which would otherwise be non-notifiable just because it involves a JB which happens to be in a kitchen. There's certainly a lot of common sense in that interpretation (which is why I feel I would have a strong defence), but I'm just not totally convinced that such is what the word of the law actually says - what is your view?
If the OP decides to run the circuit from the CU, is that also a small enough job to ignore?
If you're talking about running a 'new circuit' from the CU, that's utterly different, since there is no doubt that such would be notifiable - and no argument/defence that one could produce for not notifying. My view as to whether or not such a job should be notifiable is irrelevant (and I haven't stated it).
Kind Regards, John
