Probably just a typo but do you mean a pvc swa cable?acs2006 said:ive been onto the NICEIC and they have confirmed a pvc/pvc cable can be used to do the job. but it must obviously be isolated at the CU end.
I think you are confusing a 100A isolator on an MCB board for a fuse, the isolator doesn't provide any overcurrent protection, I think you may be pushing it on volt drop and efli for 63A on a 10mm swa cable, do you need a 63A supply, how long a run is it, what is the Ze and type of supply?so baring all that in mind. the question i seek an answer for is, if i use the henry block is it feasable to go from the henry block to some form of curcuit protection? eg a little 2 way consumer unit with its 100A fuse and a 63A MCB for example?
Sockets need to be RCD protected, for a ring main with 3 sockets would a 4mm radial be better? What is on radial to shed? 32A may be OTT.the CU in the garage will have....
6a breaker for 3 x 75w flourecents
6a breaker for garden lights (500w sec light)
32a breaker for a ring inc. 3 x 13a sockets
32a breaker for a radial to the shed inc. 1x13a socket.
acs2006 said:the reason i am doing this is because ive more or less finished my C&G 2330 and im going self employed and this project is my major works job for the NICEIC to come and look at...
acs2006 said:id prefere if u could stay out of my discussions please, and while ur staying out of my discussion you can ponder this...
swearing is the effort of a limited mind trying to express itself.
