Stoday, of course I used the figure of £5728.61 as a cost per year..THAT IS WHAT IT IS.
Lamps last longer than 4500 hours, so it can't be an annual cost
That may be the case, but never the less this is a cost that is factored in.
You don't need photocells AND timeswitches
Lamp posts are a mixture of types, some are Photo-cell operated, and some are timeclock operated and some are both, the time clock energises the circuit, but if it is not dark enough then the photo-cell stops the lamp being energised until such time as the light levels drop, equally the photo-cell turns the lamp off when light levels rise above a given point, which is before the timeclock shuts the circuit down.
Nor do you replace the head and post every year.
True, the head and post are not replaced every year on every post, many stay in place for years, but the figures take into account the fact that some posts will be replaced several times due to accidents, the fact that illuminated signs are replaced a lot more frequently than lamp posts, especially at roundabouts and many also get vandalised.
I think you will find that the costs you quote are per item not per lamp per year.
I think you will find your wrong, I am right and these figures are correct.
Now I am not saying that it is an efficient or even accurate way of doing the calculations, but this is the method used by local authorities, the Government and even the Electrical Supply industry. Now it is also highly likely that the annual budgets that local authorities put in place for this work is allowed to roll over to the following year, so the actual budget costs per year is lower than the calculated budget figure, however as it is extremely unusual for Budgets to be allowed to carry over to the following year I would be very surprised if this was the case.
I do know that within the information I have several local authorities actually stated that that any extra money within this budget was used for lighting new stretches of roadway, installing new signage, replacing existing road signage with new and redoing road line marking. Now whether other local authorities do the same thing I do not know, it was hard enough for the team to get this information as it was.
You also need to bear in mind that this is a NATIONAL AVERAGE figure, counties such as Cornwall, Cumbria, Dorset and other very riral counties actually quote quite low figures, in the region of £2000 per lamp per year, what pushes the figures up are the Metropolitan areas such as London, Manchester, Birmingham, Liverpool, Southampton, Leeds, Bradford etc tec, they have figures that are higher than the average, especially London. Each borough has it's own figures, and they are pretty similar, the average there was more than £9K per lamp per year, bear in miond the amount of road signage they hae in a given borough that gets damaged annually..I am not surprised by the figures.
I hope this clarifies it now.
