That's useful, but would it be possible to post a pic of the junction box/chock block from slightly further away, so we can see the cables and identify which wires go together? We then might be able to identify the reds in 8!
They go through a hole in the floor with all the other wires, so it may be difficult to tell. I will try and take another picture anyway.
EDIT: Two pictures, sorry about the really poor quality; the lighting is not good in that room at night. If better quality ones will help I can do them again tomorrow in daylight :
//www.diynot.com/network/MartyMalabu/albums/8578/34336
//www.diynot.com/network/MartyMalabu/albums/8578/34337
One of them stays at 0v, the other goes to 240 with CH on on the programmer - but drops to 170v with nothing on on the programmer. I tried to do a con-check from the other red to the White terminal (expecting it to be the stat, but it showed open circuit).Have you put a meter between the neutral and 8 to see if/when it goes live? Do it for each red in turn.
All the wires come into this box but are joined using the chockblock. This is how the fitter hired by Persimmons builders did it in 2002. I assume from your question this is not the standard way of doing it?Why is there a Honeywell wiring centre hiding behind the terminal strip?
