- Joined
- 8 Mar 2010
- Messages
- 276
- Reaction score
- 5
- Country
What ho one and all,
I have a well maintained Honda FG110 (mini tiller) with a GX25 engine. It has become increasingly difficult to start, but recently, it will not start at all. When it is running, it runs well.
Since the carb is the most likely cause, I bought a carb repair kit and everything has been cleaned and replaced. Nothing. Bought a complete replacement carb and still nothing.
New spark plug and ignition coil and still nothing. Checked the timing and seems perfect but that is not adjustable. Good spark, valve clearances are as the book, valves not stuck open. Dismantled and cleaned again the original, refurbed and new carbs in case drying fuel has blocked the tiny holes. Nothing.
Do not have a compression tester but with finger over the spark plug hole, there is compression but I really don't know if it is sufficient; I almost think there is insufficient compression, but what do I know?
It does occur to me that perhaps the off switch is working too well and is preventing the engine starting. I know that off switch sorta shorts the ignition pulse but does it actually stop the spark at the plug? Certainly in the run position, there is a good spark.
If it is a compression issue and the valves are closing fully, presumably the problem can be with the piston rings and /or piston itself. Can I check this without dismantling and without a compression tester?
Thanks and toodle pip
