I'm primarily a red manI'm still ahead of you on Riesling.
That's all true. Provided the voltages one is dealing with are even half-near their nominal voltages, it doesn't make a blind bit of difference where one puts the dividing lines.In practice it makes no real difference. My son would express 'pulling reasonable-sounding numbers out of the air', slightly differently. I imagine it was an off-the-cuff design decision and in practice seems to work.
Having said that, if I were doing it, whilst I would probably use numbers pulled out of the air, I think I would be inclined to have appreciably 'tighter' ranges with 'gaps' between them ("I refuse to calculate, because I'm not too sure what the nominal voltage is meant to be") - just in case someone used the device on some non-standard supply e.g. perhaps 190V-270V for 230V.
I suppose that's not a bad argument.Nevertheless the logarithmic approach seems more logical to me in general. In the specific case the nominal voltages are not equally spaced but approximately double each time.
and you!Happy drinking!
Cheers, John
