That is a similar process for testing the earthing arrangement, it is NOT the same processes for maintaining the earth system's effectiveness. .... Open circuit network Neutral, involve the DNO ... TT ground rod becoming higher than acceptable impedance, use a bucket or two of water
All true - and I agree that, from the consumer's viewpoint, dealing with a high impedance TT electrode (if the consumer were awaree of it, which will almost never be the case) is, in some sense, 'easier' than dealing with a PEN fault (although, in some senses, even the later is 'easier'; for the consumer - since they pass the entire buck to the DNO.
However, each time I respond to you, you seem to be coming back with 'moved goalposts' (or 'additional goalposts'
I was responding to you:
The balance between the effectiveness of the processes for checking these two requirements is part of the equation to decide TT or TN
... but, after I pointed out that the same 'checking process' was equally applicable to either TN or TT (so nothing to 'balance'), you have now added "the process for maintaining"
In passing, you might have added to your argument the fact that, in reality, the "bucket or two of water" (if the consumer realised it might be required, which they almost certainly won't). A TT installation relies on RCDs for fault protection. If everything in the installation is protected with 30 mA RCDs, then the impedance only has to be below about 7,666 Ω for that to work, and if there are some non-RCD circuits, such that fault protection relies on an up-front 100 mA RCD, then it needs to be below about 2,300 Ω. Unless the earth electrode becomes totally disconnected (which, again, is something of which consumers would almost never be aware) is is very unlikely that the impedance of the ear rod would get anything like that high.
I should perhaps add that, as you and others here should know, I have no 'axe to grind', in that I am no fan, let alone 'champion', of TN-C-S. In my own house, although I have been offered a TN-C-S 'earth', I have declined that offer, being much happier sticking with my TT.
Kind Regards, John
