Indeed - and in the days before washing machines, my grandmother had a vessel (which I'm almost certain was made of steel) in which she boiled up her 'washing', which was known as a "copper"
Because they were, indeed, once made from copper.
Exactly, and that's my point! ... just as telegraph poles were once for telegraphy and plumbers one worked largely with lead - but (I personally think very reasonably) we haven't felt the need to invent new words because of the changes which have occurred over time.Because they were, indeed, once made from copper.
If I had used the word 'suction' when at school, my Physics teacher would have freaked out, since he was always reminding us that such a thing (which implies that one can have a 'negative pressure') does not exist
Try telling my Physics teacher thatYou still suck on a straw, never vacuum the water
To me 1 bar was atmospheric (pretty much) so 2 bar should be 1 bar above atmospheric but it seems they talk about the bar using the atmospheric 1 bar or thereabouts as the datum rather than using zero pressure as the datum.
In daily use.What ever happened to "differential pressure" ?
In essence yes but the calibration marks can be anything relating to system pressureIt is important to know what your pressure gauge measures and IIRC manometers are all "gauge"
Yes, I've also often wondered about that. However, I suppose it's understandable that we talk of pressures 'relative to atmospheric pressure', since in all normal circumstances we are unavoidably 'within the atmosphere', hence experiencing atmospheric pressure (as a 'background reference point').A bit like the bar when relating air pressure to atmospheric. .... It used to concern me that plumbing and heating bods talked about 1 bar to 3 bar etc .
and people will happily accept a change from 10°C to 20°C is doubling the temperature but so is a change of 50°F to 100°F despite the fact 10°C=50°F and 20°C=68°F and 38°C=100°FAs you say, it's sort-of smilar with temperature, although we do then use °C to indicate when we are talking about a relative temp (relative to the freezing point of water) but use K to refer to absolute temps - less confusing than using 'bar' for both absolute and relative pressures.
Kind Regards, John
... which, of course, essentially means that there is no such thing as 'absolute' speed or velocity ...However, pressure is not the only thing we measure relative to the environment in which we normally live, hence making relative things seem absolute. We happily talk about speeds/velocities relative to the surface of the earth, and probably think of them as 'absolute' speeds/velocities, despite the fact that the surface of the earth (and hence anything moving relative to that) is moving at incredibly high speeds/velocities relative to other things in the universe.
