Yep. But some say a 12v transformer will do and others say not.There's your problem then!
came with a warning in the box about running them on unsuitable SMPS.
So, they will therefore run on suitable SMPS
you won't have a problem posting a picture of this warning then.
https://www.osram.com/osram_com/pro...-reflector-lamps/led-star-mr16-12-v/index.jsp
Just one lamp chose at random, looking at the compatibility chart tests prove works with over 90% of Electronic Transformers, even ones with a higher minimum load than the actual lamp
The secondary is rated at 11.6 V~ rms rms = Root Mean Square
The rms of a 40,000 Hz Square wave 23.2 volts chopped at 50/50 ratio can be said to have an rns value of 11.6 volts
Feeding an LED driver with 40,000 Hz may work, it may not, it may make the LED driver so unstable in operation that damage to driver and/or LED elements occurs.
That's not how they usually look though. Almost all electronic transformers for halogen lamps have a 50Hz sinewave modulated onto a >20kHz carrier frequency. As far as the 12V LED lamps are concerned, it's a 50Hz sinewave. I've never seen a 12V LED lamp without a bridge rectifier and reasonably sized capacitor after it, which would filter the carrier frequency out.
