JB277 said:In response to various questions above:
The boiler is right next to the gas meter and has all new 22mm pipe work (would switching to 28mm help?)
The only other appliance is the cooker and that's in the next room.
The governor was replaced by Transco but this didn't seem to help.
The 30mb standing pressure was going into the meter, not out in the street.
I live in North Cheam / Worcester Park and the main in the road is new apparantly. The pipe coming into mine and my neighbour's house is plastic rather than cast iron so must be fairly new.
Cheers guys!
Gasguru said:FFS
God help us in this trade.
If the service pipe is blocked the regulator ain't gonna do jack s**t.
It doesn't matter how many governor/regulators you stick on there (and I've had plenty of dumb a**e Transco engineers go down that route) the pressure won't be correct if the pressures low on the inlet to the reg due to a partially blocked service.
Why do dynamic/static pressures and flowrates on gas and water seem to cause so much confusion - its nussery school stuff
Bambergaspipe said:If the service pipe into the property was blocked then surely the Transco engineer wouldn`t be getting a reading of 30mbar into the property would he? or is it it me Just a suggestion.
Gasguru said:FFS
[Bambergaspipe]
& god help us engineers with p*rick end know it all`s like you. FFS. You only know this because you have encountered this problem & were probably stumped yourself.
You know the procedure as far as an installer is concerned, if the meter doesn`t throw the required pressure it`s usually down to the regulator. if you, as an engineer decide that it is down to the regulator, it`s down to Transco, if Transco don`t know their job, we`re all f*ucked. Get down off your high horse & go get that guy`s job. (what a dick).
Sorry mate you've been well and truly caught out. I can't help being a competent installer and knowing the difference between working and static pressures. IMHO you shouldn't be doing the job if you can't grasp this basic fact. Its got NOTHING to do with encountering the problem before.
You ain't gonna get far if you rely on everyone else knowing what their doing. I would never trust what a Transo engineer tells me or for that fact a manufacturers support desk, a sales rep or a customer. Take their advice at face value - use your brain and work it out for yourself.
Southern Gas Networks are only insterested in profit - they don't give a stuff about the customer and will hapily fob them off and rely on incompetent engineers to tow the line.
