Bambergaspipe wrote
That rules you out then .
when the major players have finished.
ANY RGI should at least be well aware of this and / or be smart enough to work it out for themselves. Anyone else working on gas should question their own position. End of Sermon (being Sunday!)
quote="croydoncorgi"]Dear oh dear oh dear!
WERE you aware of the problem I outlined?
If so, no problem for YOUR customers, then!
OTHERWISE, I think it's your turn (once again) to disappear up your own orifice.
My job is to ensure that all after & including the gas meter is safe
quote="croydoncorgi"]The point to note about this is the effective SIZE (as well as condition) of the service pipe (street to meter).
Transco / National Grid practice is to 'line' old and unserviceable steel pipes with (yellow) MDPE, from street to meter when they're re-piping the street, or from meter to street when there's an individual supply problem.
As a result, MANY service pipes in UK consist of a steel pipe which may be in a dodgy condition and partially blocked / collapsed,
Dan_Robinson said:I can't believe this stretched to 4 pages... The OP's kind of problem is just too easy to identify for it to be needed - and certainly didn't need to descend into all this sniping
FFS grow up will you!
Balenza said:
croydoncorgi said:All you've done most recently is illustrate how little you 'care' about.
I don`t care about you droning on about service pipes/ how they are laid blah -de-blah.
Maybe it would be easier to explain to your customers why a pressure problem lay with National Grid and not with your work, if you actually KNEW what the probable cause was?
I don`t usually have pressure problems, if I do & it`s down to the gas provider I`ll probably let them explain.
And customers (believe it or not)
Yep, I don`t believe you have customers
are not all so ignorant / unintelligent that they will accept everything you tell them as the complete truth, without any evidence or explanation.
Mostly they ask ``Do I have Hot water/Heating. Mostly I say ``Yes``.
Apart from my comments so far, I've nothing further to add, so please go and troll somewhere else.
You never had anything to add in the first place. After your first snipe it all rather went downhill didn`t it?
You are a man of straw CroydonCorgi.
& a man with no spine. Next.
