Ironically he sold him Powertran brand SMPS, which clearly says they are meant for halogen 12v lights!!!
So, at this stage, he should have taken them back as not fit for purpose sold for. Did he?
LOL! Would you take an item back if it is ripped out from its packaging and packaging discarded, since it cannot be sold to another customer? and for £4.00 for an item, is it worth the hassle, although in due honesty that shop would have most probably taken it back as he gets hundreds of customers, and contractors, so he probably wouldn't have had any problem taking it back, or simply swapped it with the right ones, but I buy stuff from this shop and next time i am in, I will have a word with him and he will be made aware of his mistake in selling a wrong PSU for an LED light.Ironically he sold him Powertran brand SMPS, which clearly says they are meant for halogen 12v lights!!!
Are you trying to replicate Nature? I bought some electronic tea lights and these worked on a single CR2032 battery, and had a small push to latch switch at the bottom, and a yellow led housed in a small transparent plastic housing with the tip drawn to a point to look like a candle flame, and it had quite amazing effect, light dimming and flickering effect, though I never bothered trying to see if the pattern repeats, but no one is going to notice if it does in 10 minutes let alone in 15 hours!It is a bit annoying / ironic as I have spent many hours this week creating a design for pulse width modulated supply for LED lamps to make them intentionally flicker like a real candle flame in a lantern. Waxing and waning like a candle in the breeze and not just blinking on and off. Electronics simple, but designing the "random" flicker pattern was the hardest part. ( pseudo random, it repeats after about 15 hours ).
LOL! Would you take an item back if it is ripped out from its packaging and packaging discarded, since it cannot be sold to another customer?Ironically he sold him Powertran brand SMPS, which clearly says they are meant for halogen 12v lights!!!
To be even more pedantic, that "driver" can be external to the lamp as well as within the lamp. Some "LED drivers" are external constant-current sources, hence combining the functions of what you are calling a "driver" and a "power supply".Being pendantic ( but it might help to be so )
The LED driver is the electronics in the lamp between the 12 volt power input terminals and the LED element(s). The LED driver controls the current through the LED element.
A power supply supplies power to the input of the LED lamp and then the LED driver takes what power it needs to drive the correct amount of current through the LED element.
Indeed - and this is where most of the problems arise, and why comparability between power supply, dimmer, driver (whether within or external to the lamp) and the 'lamp' itself become important. For those who don't use a set of components specifically designed to work together (i.e. of the same manufacturer/'range') it can become a total lottery. In an ideal world, there would probably be more consistency/compatibility - but we don't live in an ideal world!A dimmable LED driver will look at the input power supply and from the voltage and/or waveform decide what current to drive through the LED element. The method used to determine how much current to put through the LED element when dimming the LED varies from make to make of lamp and driver.
Indeed.I would agree a driver controls current, however for some reason the lighting industry seems to like using the wrong terms for things be it a driver, transformer, ballast or even lamp. We the user has to do is try and work out what the item really is.
Quite. I personally try to avoid the word "Qdriver", instead calling those things "constant current power supplies" and "constant voltage power supplies" - but that doesn't necessarily help when the manufacturer calls something "a driver".So ... A driver rated at 340 mA at 3 ~ 12 volt is really a driver.
A driver rated at 0 ~ 340 mA at 12 volt is in fact a power supply.
If say that was not the case and it was polarity sensitive and I put it in the wrong way that what would happenThere seems to be two diodes at the bottom so it would seem likely to work either way around. D.
I'm far from convinced that they are diodes but, even if they are, I can't think of a way of achieving polarity-insensitivity with only two - that would surely require four? Is it possible that the four components labelled "85X" are diodes?There seems to be two diodes at the bottom so it would seem likely to work either way around.
