New Boiler too powerful??
After a system has been drained it can take several days for air to be driven to the top of the rads.
Once there it has little effect on operation.
Unless your water is obviously dirty I dont think you need it flushing.
Tony
Tony
I bled the high rad in the bathroom, at first black water came out then it ran clear after a few seconds.
OK wiring has been done and it no different as expected. Current thinking is its reversed circulation. Tested the pipes and Flow and return are reversed interms of temps. Being drained and changed next week.
Do you mean the flow and return at the boiler is reversed?
Thats a serious installer error!
How did they respond?
I do hope they are correcting it free.
Depending on how and why it could only be the pump needs reversing.
Tony
So just to get this straight...
Severely oversized Boiler installed with reverse circulation, pump not wired correctly (clearly in mi's), doesn't do flushes (every new boiler needs a flush of some sort), pumping over and rads not heating.
I don't think this was installed by a plumber at all.
I think the reserve condition was probably there before. Having bought this house and having various work done I am thinking its been thrown together as quick as poss, typical 1970's job.
Wiring is all done, sparky confirmed there aren't enough wires from each point-to-point and whoever had done it before hadn't routed enough from the control centre to the boiler. Again all pre-exsiting stuff.
I bled the highest rad in the system as its really filling up with air now. initial stuff is quite black that splutters out with air then it runs clear.
Right an update,
Plumber sorted the reversed issue and sparky hadn't quite got his wires right. So now we can whack the boiler right up without problems, so thanks for everyone who made helpful comments, I learnt a lot during the course of this.
