It's a quick read.I'm sure people can look up "the successes of Brexit" themselves.
In larger businesses the risk of unfair dismissal cases does appear to put them off sacking people. Complicated area as actual working conditions and even changes in those may be seen as unfair when the case is actually tried.That is probably because you don't understand.
That's the whole point of unfair dismissal legislation.In larger businesses the risk of unfair dismissal casea does appear to put them off sacking people.
You won’t state the reason so you are lying.as i said it has nothing at all with what any politician on either side said so i have not been lied to by either side .
You on the other hand said you voted because of what you were told and were too stupid to work thing out for your self
I understand what you said.Try reading and understanding then.
You can still do that if they deserve it, it's about where you draw the unfairness line. "Managing someone out" is finding reasons where there are none.I know better, long gone of the days when you can just get rid of someone.
You know for a fact unless is gross misconduct then the process takes an age.You can still do that if they deserve it, it's about where you draw the unfairness line. "Managing someone out" is finding reasons where there are none.
I still think you are missing the "unfair" bit. If someone deserves to go then they should go, if someone doesn't deserve to go then it shouldn't be easy to make them leave.But it’s not easy
It leaves the problem that people who really should be sacked aren't. It all depends on the view point of the 2 sides. Things have slowly drifted this way over a number of years - a lot of years in some areas. You could go back to a time when some one was sacked now and again just to keep people in line. Pre WWII.That's the whole point of unfair dismissal legislation.
No, I’m taking about people who deserve it.I still think you are missing the "unfair" bit. If someone deserves to go then they should go, if someone doesn't deserve to go then it shouldn't be easy to make them leave.
Then sack them. There is nothing stopping you.No, I’m taking about people who deserve it.
You obviously don’t get involved in this side of things.Then sack them. There is nothing stopping you.
