Can you watch d.41 next time you request CH and see if its rising. The boiler fired for ~ 19secs then stayed off for ~ 42secs before coming to life again, don't know if this is some form of micro firing because if the boiler had gone into recycle then it should have stayed off for at least 2 minutes with a target temp of 65C even if the recycle time was set to 1 minute, if its set to its default setting of 20 minutes then it should have stayed off for 4.5 minutes, can you check d.01 & d.02.
If you request CH&HW together, or HW only, does it fire up then?
Next time you get it to run continuously on CH only, can you note the flow/return temps, d.40&d.41.
Your second video, just shows a steady 48C for 9 seconds, does it stay firing at 48C with a target temp of 65C?.
No. d40 is the actual flow temperature, if this is what you are getting then a dT of 28/29C is far too high and close to the burner trip point and recycle, the burner then will find it very difficult to refire successfully
