Panorama - The Smart Meter mess
Status
Not open for further replies.
If a supplier want to fit or change to prepayment now a number of considerations have to be included.
They did (have to abide by the rules) prior to 2023. It's just that unscrupulous debt collectors took it upon themselves to bypass the rules, gain warrants and run roughshod over those in debt. It's why there so many home entries and analogue meters, wrongly switched to pre-pay.
Stupid people think they are the best thing ever invented?
Quite the opposite. I've been very vocal in the admission that they are simply a meter to me. It's others that have been bigging up their capabilities, like yourself for instance.
The only benefit to me (when it works) is that it sends readings back to the supplier. Other than that, it's just a meter.
You are no more likely to be switched to pre-pay or have your supply cut off with either a SM or an analogue meter. FACT.
Still ignoring the letter and the scope of the review.
Not at all. I've read the letter which outlines concerns over SM switching. I've also noted the date. It was authored about the same time 350'000 warrants were issued by the courts to debt agency workers, in their efforts to replace analogue meters with pre-pay meters.
Just how many SM's were wrongly switched MBK?
You are no more likely to have your supply cut off or be switched to pre-payment metering with either a SM or an analogue meter. FACT.
(y)
Be lucky to get a working one full stop . When they say there is 4 million not working thats at present you could prob treble it at least at the ones that have broke and been repaired or replaced
i visit a place now and again where the smart meter works perfectly. Can even set how many readings a day are taken. 5g ok there - others flaky.
Here mine doesn't. Strange as it should be using the mobile network. No problems with that on a mobile.
Reason for fitting them - easy - no need for meter readers. Probably better estimations on bills as well.
Meter readers still required just not near as many in theory every gas meter should be visibly inspected every 2 years for various reasons . But not happening as it should
Could you say that again, in English?
פעם שבו המונה החכם עובד בצורה מושלמת. יכול אפילו להגדיר כמה קריאות ביום נלקחות. 5 גרם בסדר שם - אחרים מתקלפים.
כאן שלי לא. כמה שזה צריך להיות מוזר להשתמש ברשת הסלולרית. אין בעיות עם זה בנייד.
סיבת התאמתם - קלה - אין צורך בקוראי מונים. כנראה גם הערכות טובות יותר על שטרות.
ani mevaker bemekum medi pa'am shvu hamona hachachem oved betzura mushlamet. yechul afilu lehagdir kma kri'ot bium nilkachot. 5 gram basder shem - acharim mitkalfim.
kan shli le. kma sheza tzrich lehayot muzar lehishtamesh barshet hislularit. in be'iyot im ze baniyad.
sivet hit'amtam - kala - in tzorech bekorai monim. kanir'a gam ha'arkot tovot yoter al shtrot.
Community-verified icon
That’s a bit childish
Nope, not much better!
I agree, the SM's could have been much better, much more effective, had they only allowed use of the Internet for reporting home, but it is what it is - a system which records consumption, averaged over 30 minutes sessions, stored, then transmitted to base, at the days end. That doesn't compare well, with my unofficial system, which reports consumption, on the fly, every few seconds.
My take from offgen is that they requested a halt in switching people to prepay. They then added some considerations to be checked before switching. So suppliers then announced that they will fit them if needed. I assume after the checks have been made.
There has also been changes to what should happen if people get behind on their fuel bills.
I agree with that 100%. Total consumption depends one what people choose to buy and power up.
One thing I noticed about the house I visit where the SM works is a different style of meter and attachment that comes with it. Also no gas. I need gas and electric here but the gas meter is ~8ft from the electrics.
If you have a prepayment meter, you'll need to buy credit for your meter from a top-up point - often a local shop or Post Office. Your energy supplier will give you a top-up card or key.
If you find it hard to get to a top-up point - for example, if you’d have to travel a long way - you could get a smart meter with a prepayment setting.
If you have a smart meter in prepayment setting, you can:
  • top up using your top-up card or key
  • top up online or through an app on your mobile phone
If you top up online, you should still keep your card or key in case you need to use it - for example, if the app isn't working.
Now, if you have a non-smart meter it's very unlikely you could be cut off or have the meter changed without knowing. People coming to the house is a big clue.
And if they do, and it's an illegally obtained warrant because a supplier lied to the court and supplied false details (or they are just at the wrong address) - you also have the opportunity to look at the details and point out the error, at which point the police officer that should be part of the team will apologise for the inconvenience and send the rest of the team packing.
Now the case with a "smart" meter. Your power goes off because it's been remotely switched, you didn't know, and so didn't try to top up. Not that you can top up as your details don't tie up with the system. And you can't get YOUR supplier to turn you back on because the systems are out of sync and their's doesn't show you as on pre-pay.
No, I c.b.a. to go and find reports of just that happening.
But for me, that the system is being claimed to be "completely secure" (not possible), and it's claimed that these mistakes can't be made, plus the collection of close to 1,500 more readings than are needed to fulfil the metering function, and that these readings are thrown in a massive database also falsely claimed to be "completely secure" - all these add up to "don't want in it's current form".
Status
