after watching the video i'd say that it will definately take off
more disturbing is that harold shipman was flying the plane
The wheels have to turn balski or the plane don't go forward
Not if the no forward movement balski.
Very simple balski it doesn't matter if its impossible or not, the plane is stalled and not going anywhere.
It was on a conveyorafter watching the video i'd say that it will definately take off
After watching the video it will not take off if the plane was on a conveyor.
the wheels will, not the planeIf you stand a toy car a combi boiler or a jumbo jet on a conveyor it will move at the same speed as the belt.
but the plane moved forwards not backwards even before it had started to use its propellor thrust, according to your previous post it should have gone backwards which it didn't.In the video the weight is on the ground, all be it has a large dust sheet under the wheels
If you stand a toy car a combi boiler or a jumbo jet on a conveyor it will move at the same speed as the belt.the wheels will, not the plane
The aircraft moves in one direction, while the conveyor belt moves in the opposite direction.
If I go to Tesco and buy a plane, then stand it on the conveyor belt, it will travel to the checkout, but the wheel are not turning, Why should your plane be any different.
You are quoting me as saying all the above when a lot of it was what you said, this is confusing to others reading this threadIf you stand a toy car a combi boiler or a jumbo jet on a conveyor it will move at the same speed as the belt.the wheels will, not the plane
If it was still in its box id agreeIf I go to Tesco and buy a plane, then stand it on the conveyor belt, it will travel to the checkout
so are you saying the plane in the video was a VTOL plane?? It took off so how was it stationary then?The surface is moving, the plane is in the same spot all the time.
I think the Diynot servers HDD must have a deep groove in one particular sector considering the times this topic has been done on here and thats without any friction contactTim, I think you should now be familiar with the words,
Head, wall, and Bang..............
An aircraft is standing on a very long runway that can move (a conveyor belt). The aircraft moves in one direction, while the conveyor belt moves in the opposite direction. This conveyor belt has a control system that tracks the aircrafts wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction. There is no wind. The pilot begins to add thrust to the engines...
Will the plane ever take off?
doitall";p="901842 said:yesAn aircraft is standing on a very long runway that can move (a conveyor belt). The aircraft moves in one direction, while the conveyor belt moves in the opposite direction. This conveyor belt has a control system that tracks the aircrafts wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction. There is no wind. The pilot begins to add thrust to the engines...
No, would a ball move or just roll?I'm sure at this point you will agree anything stood on the runway will be moving at 100mph.
The original question for you balski.
the plane is standing on the runway waiting for the ok to take off.
The problem we have is the runway is moving at takeoff speed say 100mph.
I'm sure at this point you will agree anything stood on the runway will be moving at 100mph, bit like the plane on the back of a lorry doing a ton up the middle lane of the M1.
The pilot starts the engine, and has to do 100mph just to stop going backwards.
