I assure you im not being silly, think of the tyres as one continuous loop if you cut that loop and lay it out flat on the runway to achieve the endless loop we'd have to stretch the now flat tyre to an infitessimal length . agreed?Thats where you are wrong, the plane wouldnt move backwards if you turned off the thrust the wheels are freespinning. they apply no friction to the axle to push it backwards. the plane is like its sitting on an iceflow therefore applying thrust would have moved it forwards not holding it static as you imply.Lets say the wheel are now doing a 100mph, but the runway is also doing a 100mph in the opposite direction, the propulsion is holding the plane stationary, e.g. to stop it shooting backwards at a 100 mph
Don't be silly, the wheels are sat on the road, therefor if the road is doing 100mph the plane and anything will also do 100mph, by applying thrust you can stop the backward travel, but the guy stood in the middle of the runway would have to hang on like grim death
now the tyre is attached as you say to the runway by the tyres traction agreed?
the tyre track will run off with the runway at the runway/conveyor speed agreed?
now look at the top surface of this tyre track, its extremely slippery has no friction and therefore the planes axle would just slip on it if pushed agreed?
apply the push with the thrust and hey presto the plane moves forward regardless of what the runway and tyre track are doing.
