heres a puzzle you wont get,
whats 38 and 20 come too ?
Barry White of course.
nope .........well atleast i dont think i look like him anyway
It won't take off, following the OP's original question.
Obviously there are a lot of clever people trying to correctly answer this poser,
but the plane needs airspeed over and under its wings to lift its bulk off the ground.
If the conveyor can keep up with the thrust of the engines,
then the plane will just make a lot of noise / heat etc. and not much else.
not the plane, the axle inside the wheel is skiddingbut thats the whole point it is skidding internallyThe plane cannot travel farther than the turn of the wheel, unless it's plaining or skidding.
And the storm is getting quite bad so I'm logging off in a minute
The plane doesn't skid during take off it rolls, or rolling as we tell the control tower
Complete tripe.
Once the engines provide thrust it then becomes totally irrelevant what the wheels are doing in relation to the conveyor.
If the wheels from standstill to take off revolve at say an average of 1500 rpm without a conveyor then add a conveyor and the wheels will revolve at a much higher rpm depending on the rpm of the conveyor.
Which it will have once the engines provide thrust.
Which is impossible. Increase the conveyor speed as much as you like and you will only increase the wheel rpm.
It's simple really.
now youre being very silly, its a simple thing to understand.So the axle is turning but not the wheels
Why is the plane going backwards with no friction between the ski's and the runway?? do you understand the concept of friction?Lets do away with the wheels to make it easy for you guys, and add ski's
The plane is sitting on the conveyor doing 100mph backwards, ok so far
how do you have contact without friction? the plane is floating not in contact due to the frictionless ski'sBecause that is the speed of the conveyor, anything on it will be doing the same speed, and there's no friction because contact with the belt is static
In the middle lane?The plane is not floating its parked on the surface, no different to being on the back of a lorry going up the M1
