PIR/EICR
I work on domestic properties so ....
I can't believe you really are an electrician - your comments and single minded belief that you have the power and authority to come into someones property and disconnect their supply without their say is beyond pail - you really are away with the fairies aren't you or maybe your just a troll in disguise.
last night said:
vibrobullit407 said:
As I truly thought that I was using the wrong terminology. I actually had to look it up to find that the terminology was the same as BS7671.
I'm past the stage of having any confidence that I know what you 'truly think'. As I've said/implied, from where I'm standing it looks as if you've either been playing with folk here or else you're a rather odd sort of electrician.
Kind Regards, John
akin to going to a doctor for a routine checkup and being told that you were not going to be allowed to go home until your kidney had been removed.
Not as bad as being a private patient having a series of tests and being asked, part way through, if you wouldn't mind settling your account up to date....
