So how does it work when there is a hot water demand and the combi stops the heating?
Whats your back ground than onetap air con ? controls ?( interested )
Thermal Man has gone quiet suddenly, he's usually very quick with his responses.
You are talking nonsense as usual. Most AHUs do not take in 100% outside air, only a percentage. On a well sized coil WC works brilliantly with AHUs. The ATAG Brain Z has setting for them. Even frost protection. Read what I wrote. Get back on what you do not understand.
It is a combi in a domestic house. When DHW is called, the heat is not sent to the AHU. The recovery is zippo as the ouput of the boioer is 35kW in a demand of 15-16kW, using a 20kW AHU coil.
Obviously domestic is different but could the same not be acheived from a combi boiler with a buffer/thermal store added?
Is the hydronic circuit of fan coils usually variable volume with constant temperature and whats the disadvantage with variable temperature-constant volume? More accurate control with the former I'm guessing.
It wasn't. The 3-way modulating valve on the AHU varied the coil temp, with amin temp set to avoid cool draughts. Vaiable temp, fixed air volume.
The flow loop to the ASHU will be a constant temp, The AHU's take this constant temp and mix it with the cool return from the coil.
Try copper industries in Toome.... They do a range of thermal stores...
http://www.copperindustries.co.uk/technical-info.php
Like most they will make you a unit exactly of your design.
Go for domes top and bottom and zip it up to some unistrut so the cylinder is in effect wall mounted and then sludge is less of a problem. Have done it and is quite easy.
Then fit your own plate and flo switch.
Used to fit the indoor Unico air handlers in commercial premises.
We didn't fit any fresh air duct. It was a constant volume air supply 100% recirculated. The fan was very silent.
Its an american system and mainly aimed at the domestic market afaik.
(They recommended a glycol mixture for their outdoor units to prevent freezing)
Anyway these units were supplied from a thermal store.
