Plug in wall heaters - scam?
I’m and am sure a lot of others too, keep seeing these online ads for these low energy plug in the wall ceramic heaters costing circa £20. I think they’re a scam or even if real, only give out a small amount of heat and are probably a fire hazard.
Low energy means low output.
Are all electric fan heaters the same in respect of efficiency? They all heat up an element which the fan then blow out the hot air.
Yes
How can we search for an buy a more energy efficient fan heater.
You can’t. All electric heaters are 100% efficient except heat pumps which are around 250%. But they are expensive to run because electricity is 3 1/2 times the cost of gas.
I’m used to buying the £15 2kw ones on Amazon.
OK.
