It may be literally true that the 'shock hazard' is significant but, unless you live in a cottage which is unheated and with walls constantly covered in mould...
... Seriously the walls have no damp proof so are internally conductive. There was a detectable "tingle" between the chuck of a double insulated drill and the wall before the heating was installed.
...I seriously doubt that you'd every get anything like enough current through you by touching the interior surface of a wall to represent a significant threat to your life, even if the potential of your CPCs (hence exposed-c-ps, like your kettle) rose to 230V.
The damp wall is not a serious risk of electrocution but reaction to the tingle might lead to a consequential accident.
Literally true but, as below, this may be one of those situations in which your risk perception and assessment may be different from that of others. Accidentally touching a hot part of the kettle (without touching anything else, and without any electrical issues) might also 'make you jump' and suffer a consequential accident.
Bernard is certainly no fool...
Taking on this cottage proves I might be
25 years ago, I took on a home which, at least in terms of scale, may be even greater proof that
I am a fool - and, 25 years on,the 'project' is most certainly still 'ongoing'!
but reasoned on the basis of premises and assumptions about probabilities (i.e. 'risks'), and relative probabilities, which many of us may disagree with.
That sums it very well. ...
Within reason, there's nothing particularly wrong in erring on the side of caution, provided one is careful not to assess relative risks incorrectly (some people may think that the 'metal bath' is an example) - but it can become a bit restrictive, and unnecessarily intrusive on one's life if taken too far. If one travels in cars, crosses roads and uses ladders and power tools, then one has, in some senses, defined a level of risk that one is prepared to 'accept', and perhaps should apply that same 'level of acceptable risk' across all aspects of one's life.
I grew up in the time of change from "earth wires" that really were earth via the water pipe, through "earth wires" that were only a monitoring wire on behalf of a voltage operated isolator which cut the supply when the "earth wire" went above a safe voltage (*) and on to RCDs and PME and its varients. ...(*) this voltage operated method would be the ideal system had it not been that low impedance alternative paths from the monitoring wire ( so called "earth" wire ) to true ground meant very high fault to "earth" currents could be flowing without the voltage becoming high enough to trip the voltage operated circuit breaker.
As I've said before, as I see it, there is no obvious reason why one could not still have the 'best of all worlds' if one wanted. Have all the modern things, but also have a
(truly) voltage-operated breaker (and earth electrode) sensing the pd between CPCs and 'true earth', with the breaker (or a separate one) also triggered by excessive current in the 'earthing conductor' (sensed by running it through a current sensing toroid). Provided that it was a truly voltage-operated device (easy with modern electronics), it would not require any impedance to be introduced into the CPC/earthing system, and the threshold could be set such as to reduce the extent to which 'parallel paths to earth' would undermine its functionality. As far as I can see, nothing in the regs would prohibit any of that and, although far from foolproof, would further reduce some of the (already very low) risks that concern you.
Kind Regards, John
