Yes, I am aware of all that. [it's interesting that the second document you quote indicates a number of types of loads, including cooking appliances, which, individually, have a 'maximum leakage of 10mA - and 10mA is, of course, more than 9mA]This is from BS7671, and where the 30% limit for leakage current is from: .... 30% of a 30mA RCD being 9mA. .... This is a sample of leakage currents for a selection of equipment. ....
Indeed - but even 531.3.2(i) contains the words "likely to occur" - and the "such currents" mentioned in 531.3.2(ii) are presumably those "likely to occur" ones mentioned in 531.3.2(i).531.3.2 first appeared in the 18th edition in 2018. ... Section 314 which is Division of Installation has been in there for decades, since the 15th edition.
Whilst what you say about the proliferation of things like switching power supplies is certainly true, I cannot help but wonder whether this is not a case of 'theory over-riding experience and common sense'. That is certainly the case with my personal experience. I have some circuits which have many (a dozen or more) connected items with SMPSUs (quite apart from whatever might be connected to other circuits protected by the same RCD) and I know that has not resulted in problems due to earth leakage currents - since I have virtually never experienced any operation of an RCD 'without good reason'.The relatively recent prevalence of everything having electronics inside, and specifically switching power supplies, has significantly increased the leakage current for a very large number of items, including those which previously had little or none. Modern homes typically have vastly more items of equipment than those of only a decade ago.
There is no reason why my experience should be unique, so I wonder how many people actually have experienced RCD trips which they think may have been due to excessive 'leakage currents in normal operation' of connected loads?
Kind Regards, John
