If it is to be buried, you need to use steel wired armoured cable, buried at a suitable depth, so i hope you like digging.
PBC has only fairly recently departed the UK shores and made his new home across the water, so I don't think you need to worry about the (correct) advice you have been given.I am not an expert, but i'm not sure if US rules are the same as UK(?), unless i get an expert's view from the UK, my "question" is unanswered and this is not offensive meant!!!
I can't imagine that there is any country in the world in which that advice would not be correct.I am not an expert, but i'm not sure if US rules are the same as UK(?), unless i get an expert's view from the UK, my "question" is unanswered and this is not offensive meant!!!There is never a problem with using a switch which is rated higher than you need. The 45A rating is simply the maximum that the switch is designed to carry safely
Yes it will be, you need to use a use a 13A FCU if you are spurring off of the ring final, a metalclad one would be good so you can properly gland the armoured cable. Metalclad socket and switchfuse the other end would make this easier too.does it matter if it is 45A? As far as I understand it is "just" a switch!
You won't find a 45A FCU - You would need to use an unswitched FCU (maximum fuse possible is 13A) then feed into the 45A switch.Right, so no problem with the 45 Amp FCU;
SWA (Steel Wire Armored) has become the traditional cable type for underground use in the U.K. If you check around, you may well find you can obtain it cheaper than the HYY-J.and do i understand correctly PBC_1966, that the cable, reading the info on the link, is suitable for underground installation, so practically i won't need the armored one!!
The 20mm measurement is the outside diameter of the conduit The internal bore is less than that by twice the wall thickness. In reality, you would probably have about 15- 17 mm internal diameter to play with. I would even try to get a 13.5mm dia. cable through it, even on a straight run, never mind with a couple of bends.As about the cable size with a nominal over all diameter of 13.5mm, it shouldn't be much of a problem to feed it through a conduit bend, i still got 6.5mm play room; being aware of the (possible) difference in size between manufacturers!
Personally, I would take the SWA directly into a metalclad double socket,,up in the shed, into a junction box
i will change to 25mm conduit
All agreed, but ....Why do you want to use a 45A switch in addition to a 13A FCU? Not that it's unsafe to do so but it achieves nothing if the 13A FCU already includes a switch and limits the maximum load to 13A. ... If you really want another switch, use a 20A one, it will me more than adequate and will leave more wiring room in the box than the bulkier 45A version.
The reason for me asking is, the 45A has a switch that requires a good amount of force to switch on/off whereas the 13A can be switched on/off by the press of a finger. The location of the switch will be behind a cupboard, quite low, and i am afraid if someone is trying to access the (feeding) double socket next to it, might switch it off without realising it. Needless to say the adults in the house are going to be aware of it but you never know.....!
