Well, as you say, there's the cabling to consider, as you'd have to get two lots into the outgoing terminals of the incomer, or take them to a couple of rail-mounted distribution terminals, e.g.
And of course you'd have to get more singles to use inside the CU.
And you're going to lose space for MCBs.
Then you'd have to shorten one of the busbars, as it would be designed to come out of the incomer.
And (I think?) you'd need to split the normally non-RCD neutral bar in two.
Mind you - I found this on the Hager website, so maybe if you want one, you can buy one ready made from them:
