M
mysteryman
Perhaps they can't be bothered in the face of opposition from the very people who should be installing it!
The real issue here is one of complete understanding. A boiler with external on-off controls can only modulate to a fixed flow temperature, which has to be kept high in case of need in severe weather. The control mentioned by the OP is an on-off control, so the boiler is short-cycling which is not the best form of control. If you add a downstream flow temperature sensor you can on-off control it at variable temperature, but then the burner is not modulating. Still not the best form of control. If you add a device to make it modulate at variable temperature so as to match the building's heat demand, you have the best form of control. This has the additional advantage that the variable flow temperature will be below condensing temperature most of the time [or all the time with underfloor heating]. This device is readily available. It is weather compensation. In order to modulate at variable temperature, it needs to be 'inside' the boiler, or as an integral part of the boiler. It can't be properly effective as an external add-on.
The successful manufacturers have thought all this out for you, and they do indeed have all the answers, even to questions you may not have asked.
